usb cdc pic18f14k50
31.03.2013, 22:56
Сказал спасибо: 148
Сказали Спасибо 166 раз(а) в 118 сообщении(ях)
usb cdc pic18f14k50
понадобился сей девайс pic18f14k50. нагуглил http://sturntech.com/blog/2010/10/21...pheral-device/
собрал в протезе - то ли проблема с дровами, то ли с головой. помогите как дрова воткнуть.
протеусовские поставил. как видно из вложения находит определяет.
01.04.2013, 22:50
Сказал спасибо: 148
Re: usb cdc pic18f14k50
вроде начало получатся. дрова встали. дело пошло.
04.04.2013, 19:15
Сказал спасибо: 148
13.04.2013, 23:21
Сказал спасибо: 148
вот возник трабл. речь о "Device - CDC - Serial Emulator" на пик18ф14к50
для тех кто в теме есть "HARDWARE_PROFILE" в Microchip Solutions v2012-10-15\USB
FileName: HardwareProfile.h
Dependencies: See INCLUDES section
Processor: PIC18, PIC24, dsPIC33, or PIC32 USB Microcontrollers
Hardware: This demo is natively intended to be used on Microchip USB demo
boards supported by the MCHPFSUSB stack. See release notes for
support matrix. The firmware may be modified for use on
other USB platforms by editing this file (HardwareProfile.h)
and adding a new hardware specific
HardwareProfile - [platform name].h file.
Compiler: Microchip C18 (for PIC18), C30 (for PIC24/dsPIC33), or C32 (for PIC32)
Company: Microchip Technology, Inc.
Software License Agreement:
The software supplied herewith by Microchip Technology Incorporated
(the "Company") for its PIC® Microcontroller is intended and
supplied to you, the Company's customer, for use solely and
exclusively on Microchip PIC Microcontroller products. The
software is owned by the Company and/or its supplier, and is
protected under applicable copyright laws. All rights are reserved.
Any use in violation of the foregoing restrictions may subject the
user to criminal sanctions under applicable laws, as well as to
civil liability for the breach of the terms and conditions of this
license.
THIS SOFTWARE IS PROVIDED IN AN "AS IS" CONDITION. NO WARRANTIES,
WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT NOT LIMITED
TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. THE COMPANY SHALL NOT,
IN ANY CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL OR
CONSEQUENTIAL DAMAGES, FOR ANY REASON WHATSOEVER.
#ifndef HARDWARE_PROFILE_H
#define HARDWARE_PROFILE_H
//#define DEMO_BOARD USER_DEFINED_BOARD
#if !defined(DEMO_BOARD)
#if defined(__C32__)
#if defined(__32MX460F512L__)
#if defined(PIC32MX460F512L_PIM)
#include "HardwareProfile - PIC32MX460F512L PIM.h"
#elif defined(PIC32_USB_STARTER_KIT)
#include "HardwareProfile - PIC32 USB Starter Kit.h"
#endif
#elif defined(__32MX795F512L__)
#if defined(PIC32MX795F512L_PIM)
#include "HardwareProfile - PIC32MX795F512L PIM.h"
//PIC32 USB Starter Kit II
#endif
#endif
#endif
#if defined(__C30__) || defined __XC16__
#if defined(__PIC24FJ256GB110__)
#include "HardwareProfile - PIC24FJ256GB110 PIM.h"
#elif defined(__PIC24FJ256GB210__)
#include "HardwareProfile - PIC24FJ256GB210 PIM.h"
#elif defined(__PIC24FJ256GB106__)
#include "HardwareProfile - PIC24F Starter Kit.h"
#elif defined(__PIC24FJ64GB004__)
#include "HardwareProfile - PIC24FJ64GB004 PIM.h"
#elif defined(__PIC24FJ64GB502__)
#include "HardwareProfile - PIC24FJ64GB502 Microstick.h"
#elif defined(__PIC24FJ256DA210__)
#include "HardwareProfile - PIC24FJ256DA210 Development Board.h"
#elif defined(__dsPIC33EP512MU810__)
#if defined(DSPIC33EP512MU810_PIM)
#include "HardwareProfile - dsPIC33EP512MU810 PIM.h"
#endif
#if defined(DSPIC33E_USB_STARTER_KIT)
#include "HardwareProfile - dsPIC33E USB Starter Kit.h"
#endif
#elif defined(__PIC24EP512GU810__)
#if defined(PIC24EP512GU810_PIM)
#include "HardwareProfile - PIC24EP512GU810 PIM.h"
#endif
#endif
#endif
#if defined(__18CXX)
#if defined(__18F4550)
#include "HardwareProfile - PICDEM FSUSB.h"
#elif defined(__18F45K50)
#include "HardwareProfile - PICDEM FSUSB K50.h"
#elif defined(__18F87J50)
#include "HardwareProfile - PIC18F87J50 PIM.h"
#elif defined(__18F97J94)
#include "HardwareProfile - PIC18F97J94 PIM.h"
#elif defined(__18F87J94)
#include "HardwareProfile - PIC18F87J94 PIM.h"
#elif defined(__18F14K50)
#include "HardwareProfile - LPC USB Development Kit - PIC18F14K50.h"
license.
#endif
#endif
#endif
#endif
#endif
#endif
#endif
#endif
#endif
#elif defined(__18F46J50)
#include "HardwareProfile - PIC18F46J50 PIM.h"
#elif defined(__18F47J53)
#include "HardwareProfile - PIC18F47J53 PIM.h"
#endif
#endif
#if defined(_PIC14E)
#if defined (_16F1459)
#include "HardwareProfile - LPC USB Development Kit - PIC16F1459.h"
#endif
#endif
#endif
#error "Demo board not defined. Either define DEMO_BOARD for a custom board or select the correct processor for the demo board."
#endif
#endif //HARDWARE_PROFILE_H
defined(__18F46J50)
#endif
#endif
#endif
#endif
#endif
#endif
#endif //HARDWARE_PROFILE_H |
я чищу код от #if приводя код под свой мк подчистил до
#endif
#endif
#endif
получаю естественно BUILD FAILED
с "C:\Microchip Solutions v2012-10-15\USB\Device - CDC - Serial Emulator\Firmware\HardwareProfile.h:50:Error [1099] "Demo board not defined. Either define DE...тарампампам..."
вопрос где в микрочиповской версии дефайнится демо борда? USER_DEFINED_BOARD не катит.
котэ помоги
Последний раз редактировалось gromovi; 13.04.2013 в 23:39.
14.04.2013, 00:41
Сказал спасибо: 928
gromovi, Выключи этот хэдер и замени на
он там же лежит .
Заодно мануал скачай на эту борду.
Я HID проверял в протеусе . Дык даже бутлоадер работает .
Видно обновление в Programm memory ...
Осторожно , злой кот
Последний раз редактировалось dosikus; 14.04.2013 в 00:47.
Сказали "Спасибо" dosikus
14.04.2013, 00:42
Сказали Спасибо 26 раз(а) в 21 сообщении(ях)
PHP код:
#define DEMO_BOARD LOW_PIN_COUNT_USB_DEVELOPMENT_KIT
#define LOW_PIN_COUNT_USB_DEVELOPMENT_KIT
#define CLOCK_FREQ 48000000
#define GetSystemClock() CLOCK_FREQ
в файле HardwareProfile - Low Pin Count USB Development Kit.h
picping.lg.ua
Сказали "Спасибо" Driver_gv
14.04.2013, 00:45
Сказал спасибо: 928
Сообщение от gromovi
Если у тебя Win7 64 - жди беды , у меня эти дрова хорошо насрали .
Пришлось откат делать . Теперь подобные экскременты только на виртуалке.
О чем кстати и разработчики дров предупреждали ...
Последний раз редактировалось dosikus; 14.04.2013 в 00:48.
14.04.2013, 17:03
Сказал спасибо: 148
Сообщение от dosikus
да беда была. проблема больше касается дебага. да хрен с ним в железе юзать буду.
14.04.2013, 17:13
Сказал спасибо: 928
gromovi, У меня слетели все USB примочки/дебуггеры .
Просто не опознавались системой.
21.04.2013, 15:31
Сказал спасибо: 148
вернулся к вопросу. свободное время редко бывает, потому такое "затягивание". Зато есть куча времени подумать. Подумал... не надо ничего чистить. Нужно настроить модуль в режим SPI, ловить момент заполнения буфера на вход выход. Как?
PHP код:
void ProcessIO(void)
//Blink the LEDs according to the USB device status
BlinkUSBStatus();
// User Application USB tasks
if((USBDeviceState ‹ CONFIGURED_STATE)||(USBSuspendControl==1)) return;
if (RS232_Out_Data_Rdy == 0) // only check for new USB buffer if the old RS232 buffer is
{ // empty. This will cause additional USB packets to be NAK'd
LastRS232Out = getsUSBUSART(RS232_Out_Data,64); //until the buffer is free.
if(LastRS232Out › 0)
RS232_Out_Data_Rdy = 1; // signal buffer full
RS232cp = 0; // Reset the current position
//Check if one or more bytes are waiting in the physical UART transmit
//queue. If so, send it out the UART TX pin.
if(RS232_Out_Data_Rdy && mTxRdyUSART())
#if defined(USB_CDC_SUPPORT_HARDWARE_FLOW_CONTROL)
//Make sure the receiving UART device is ready to receive data before
//actually sending it.
if(UART_CTS == USB_CDC_CTS_ACTIVE_LEVEL)
putcUSART(RS232_Out_Data[RS232cp]);
++RS232cp;
if (RS232cp == LastRS232Out)
RS232_Out_Data_Rdy = 0;
#else
//Hardware flow control not being used. Just send the data.
++RS232cp;
#endif
//Check if we received a character over the physical UART, and we need
//to buffer it up for eventual transmission to the USB host.
if(mDataRdyUSART() && (NextUSBOut ‹ (CDC_DATA_OUT_EP_SIZE - 1)))
USB_Out_Buffer[NextUSBOut] = getcUSART();
++NextUSBOut;
USB_Out_Buffer[NextUSBOut] = 0;
//Drive RTS pin, to let UART device attached know if it is allowed to
//send more data or not. If the receive buffer is almost full, we
//deassert RTS.
if(NextUSBOut ‹= (CDC_DATA_OUT_EP_SIZE - 5u))
UART_RTS = USB_CDC_RTS_ACTIVE_LEVEL;
else
UART_RTS = (USB_CDC_RTS_ACTIVE_LEVEL ^ 1);
#endif
//Check if any bytes are waiting in the queue to send to the USB host.
//If any bytes are waiting, and the endpoint is available, prepare to
//send the USB packet to the host.
if((USBUSARTIsTxTrfReady()) && (NextUSBOut › 0))
putUSBUSART(&USB_Out_Buffer[0], NextUSBOut);
NextUSBOut = 0;
CDCTxService();
}//end ProcessIO
void CDCTxService(void)
BYTE byte_to_send;
BYTE i;
USBMaskInterrupts();
CDCNotificationHandler();
if(USBHandleBusy(CDCDataInHandle))
USBUnmaskInterrupts();
return;
* Completing stage is necessary while [ mCDCUSartTxIsBusy()==1 ].
* By having this stage, user can always check cdc_trf_state,
* and not having to call mCDCUsartTxIsBusy() directly.
if(cdc_trf_state == CDC_TX_COMPLETING)
cdc_trf_state = CDC_TX_READY;
* If CDC_TX_READY state, nothing to do, just return.
if(cdc_trf_state == CDC_TX_READY)
return;
* If CDC_TX_BUSY_ZLP state, send zero length packet
if(cdc_trf_state == CDC_TX_BUSY_ZLP)
CDCDataInHandle = USBTxOnePacket(CDC_DATA_EP,NULL,0);
//CDC_DATA_BD_IN.CNT = 0;
cdc_trf_state = CDC_TX_COMPLETING;
else if(cdc_trf_state == CDC_TX_BUSY)
* First, have to figure out how many byte of data to send.
if(cdc_tx_len › sizeof(cdc_data_tx))
byte_to_send = sizeof(cdc_data_tx);
else
byte_to_send = cdc_tx_len;
* Subtract the number of bytes just about to be sent from the total.
cdc_tx_len = cdc_tx_len - byte_to_send;
pCDCDst.bRam = (BYTE*)&cdc_data_tx; // Set destination pointer
i = byte_to_send;
if(cdc_mem_type == USB_EP0_ROM) // Determine type of memory source
while(i)
*pCDCDst.bRam = *pCDCSrc.bRom;
pCDCDst.bRam++;
pCDCSrc.bRom++;
i--;
}//end while(byte_to_send)
else // _RAM
while(i)
*pCDCDst.bRam = *pCDCSrc.bRam;
pCDCDst.bRam++;
pCDCSrc.bRam++;
i--;
}//end while(byte_to_send._word)
}//end if(cdc_mem_type...)
* Lastly, determine if a zero length packet state is necessary.
* See explanation in USB Specification 2.0: Section 5.8.3
if(cdc_tx_len == 0)
if(byte_to_send == CDC_DATA_IN_EP_SIZE)
cdc_trf_state = CDC_TX_BUSY_ZLP;
else
}//end if(cdc_tx_len...)
CDCDataInHandle = USBTxOnePacket(CDC_DATA_EP,(BYTE*)&cdc_data_tx,byte_to_send);
}//end if(cdc_tx_sate == CDC_TX_BUSY)
}//end CDCTxService
#endif //USB_USE_CDC
Часовой пояс GMT +4, время: 08:46.
