нужен исходник на Си
Непрочитано 08.04.2007, 16:56
pln14
Сказали Спасибо 17 раз(а) в 4 сообщении(ях)
pln14 на пути к лучшему
По умолчанию нужен исходник на Си
Доюрый день!
Помогите кто чем сможет.
нужна программа на Си для измерения частоты
PIC контроллером. Диапазон от 0 до 10 кГц
pln14 вне форума
Непрочитано 08.04.2007, 17:56
dosikus
Аватар для dosikus
Сказал спасибо: 928
dosikus на пути к лучшему
////                             EX_FREQC.C                          ////
////  Counts the 'zero' crossings of an input signal for 1 second,   ////
////  therefore counting the frequency of the signal.  The input     ////
////  signal's frequency is then displayed over the serial port.     ////
////  The 1s delay is created by generating a perfect 5,000,000      ////
////  cycles (it takes 0.2us for one cycle at 20Mhz).  The trick is  ////
////  that conditional statements have different values of cycles    ////
////  depending on a TRUE or FALSE jump.                             ////
////  The input signal is to be supplied to pin C0                   ////
////  This example will work with the PCM compiler.  The             ////
////  following conditional compilation lines are used to include a  ////
////  valid device for each compiler.  Change the device and clock   ////
////  for your hardware if needed.                                   ////
////        (C) Copyright 1996,2003 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
#include ‹16F877.h›
#fuses HS,NOWDT,NOLVP
#use delay(clock=20000000)    //one instruction=0.2us
#use rs232(baud=9600, xmit=PIN_c6, rcv=PIN_c7)
#bit t1_overflow=0x0C.0
// #bit t1_overflow=0xF9E.0  (PIC18, Reminder)
void main() {
   int cycles8, cycles;
   int32 freq;
   long freqc_high;
   long freqc_low;
   while (TRUE) {
      cycles8=0;
      cycles=0;
      freqc_high=0;
      t1_overflow=0;
      set_timer1(0);
      setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
/* ___ wait one second ___  */
      while (cycles!=0xFF) { //true=3, false=4
       cycles8=0; //1 cycle
       //start inner loop
       while (cycles8!=0xFF) { //true=3, false=4
         if (t1_overflow)//true=2,false=3             //----|
            {t1_overflow=0;freqc_high++;}//6 cycles   //    |
         else                                         //    |-- 8 cycles
            {delay_cycles(5);}                        //----|
         delay_cycles(62); //x
         cycles8++; //1
 ///2 cycles to jump to top
 //math: end inner loop
 //math: total inner loop=((3+8+x+1+2)*255 + 4)*255
 //math: if x=62.87781 then inner loops takes 5mil instructions
 //math: if x=62 then inner loop takes 4942920, have to fill 57080 cycles
 delay_cycles(216);      //y
 cycles++;          ///1 cycle
 ///2 cylces to jump to top
 //math: outer=(3+1+y+1+2)*255+4=57080
 //math: y=(57080-4)/255)-(3+1+0+0+1+2)
 //math: if y=216.827450980392156862745098039216 then outer loop cylces is 57080
 //math: if y=216 then outer loop cycles is off by 211 cycles.  z=211
      delay_cycles(211);   //z
/* ___ end waiting 1 second ___ */
      setup_timer_1(T1_DISABLED);   //turn of counter to prevent corruption while grabbing value
      if (t1_overflow)            //check one last time for overflow
          freqc_high++;
      freqc_low=get_timer1();      //get timer1 value as the least sign. 16bits of freq counter
      freq=make32(freqc_high,freqc_low);   //use new make32 function to join lsb and msb
      printf("%LU Hz\r\n",freq);      //and print frequency
dosikus вне форума
Непрочитано 08.04.2007, 17:58
dosikus
Аватар для dosikus
Сказал спасибо: 928
Извини до 10 кгц не нашлось есть на 50 мгц
Выдрал из примеров CCS...
EX_FREQC.C
A 50 mhz frequency counter
dosikus вне форума
Непрочитано 08.04.2007, 18:26
urry
Аватар для urry
urry на пути к лучшему
фика себе задача поставлена... А дискретизация (точность ?)Скока разрядов ? Какая частота кварца ? Какой контроллер ? На когда надо ?
У докусика 32 разряда и 20 мегагерц, в общем, хватит наверняка...
urry вне форума
Непрочитано 08.04.2007, 18:47
pln14
Благодарю, Dosikus
на асме несколько вариантов видел,
а на Си этот первый!
попробую перелепить под свои нужды
pln14 вне форума
Непрочитано 08.04.2007, 18:55
dosikus
Аватар для dosikus
Сказал спасибо: 928
Не забудь , что писано для CCS PICC .
dosikus вне форума
Непрочитано 08.04.2007, 19:00
pln14
для urry
PIC16F84
кварц-4МГц
точность- 5 разрядов
работа факультативная на общественных началах,
поэтому сроки не оговариваются
pln14 вне форума
Непрочитано 08.04.2007, 19:12
dosikus
Аватар для dosikus
Сказал спасибо: 928
Как всегда видишь-не надо,как понадобиться хрен найдешь.
Роюсь по нету и ничего на С не нахожу....
dosikus вне форума
Непрочитано 08.04.2007, 19:40
urry
Аватар для urry
под 16ф84 прога не прокатит. Если не ошибаюсь (давно не программировал на 84) там таймера 1 в принципе нет, там таймер 0 и он 8-разрядный, а не 16 - как в проге. Хотя, если честно... не помню... в последнее время возился с пик 12 ...Короче, проще написать самостоятельно.Счас на работе мучаюсь с биллингом, только в среду вечером смогу написать и отладить. Если устраивает, дайте ответ. Работы немного...
urry вне форума
Непрочитано 08.04.2007, 20:09
dosikus
Аватар для dosikus
Сказал спасибо: 928
Можно переделать на 628...
Но заявка была (см шапку) на PIC вообще...
dosikus вне форума
Кодовый замок. Исходник и схема maagalex Автоматика и аппаратура связи 12 04.12.2015 16:27
исходник програматора vas414 Микроконтроллеры, АЦП, память и т.д 3 24.01.2009 23:55
Почему протеус ненаходит исходник kovza Микроконтроллеры, АЦП, память и т.д 2 24.10.2008 18:31
Помогите поправить исходник afisha-4s Микроконтроллеры, АЦП, память и т.д 9 08.08.2007 04:21
EEPROM исходник для PROTEUS. greesha_demchuk Proteus 1 10.03.2007 12:27
Часовой пояс GMT +4, время: 01:33.
