Библиотека SSD1289
Непрочитано 12.11.2010, 19:49
kison
kison на пути к лучшему
По умолчанию Re: Библиотека SSD1289
А какой текущий такт? Встроенный RC или PLL с кварцем?
kison вне форума
Непрочитано 12.11.2010, 20:19
Uragan90
Аватар для Uragan90
Сказал спасибо: 469
Uragan90 на пути к лучшему
Сейчас встроенный RC!
Кстати вот нашел процедуру работы с моим дисплеем!
PHP код:
void WriData(uint ch)
    LCD_RS_1;
    LCD_WR_1;
    LCD_CS_0;
    LCD_DATA(ch);
    LCD_WR_0;
    LCD_CS_1;
void WriCom(uint ch)
    LCD_RS_0;
    LCD_WR_1;
    LCD_CS_0;
    LCD_DATA(ch);
    LCD_WR_0;
    LCD_CS_1;
void write_com(uint address,uint num)
    WriCom(address);
    WriData(num);
void TftInit(void)
    LCD_RESET_0;      //µНµзЖЅёґО»
    DelayMs(10);
    LCD_RESET_1;
    write_com(0x0000,0x0001);    DelayMs(10);  //ґтїЄѕ§Хс
    write_com(0x0003,0xA8A4);    DelayMs(10);   //0xA8A4
    write_com(0x000C,0x0000);    DelayMs(10);
    write_com(0x000D,0x080C);    DelayMs(10);
    write_com(0x000E,0x2B00);    DelayMs(10);
    write_com(0x001E,0x00B0);    DelayMs(10);
    write_com(0x0001,0x2B3F);    DelayMs(10);   //Зэ¶ЇКдіцїШЦЖ320*240  0x6B3F
    write_com(0x0002,0x0600);    DelayMs(10);
    write_com(0x0010,0x0000);    DelayMs(10);
    write_com(0x0011,0x6070);    DelayMs(10);        //0x4030           //¶ЁТеКэѕЭёсКЅ  16О»Й«
    write_com(0x0005,0x0000);    DelayMs(10);
    write_com(0x0006,0x0000);    DelayMs(10);
    write_com(0x0016,0xEF1C);    DelayMs(10);
    write_com(0x0017,0x0003);    DelayMs(10);
    write_com(0x0007,0x0233);    DelayMs(10);        //0x0233
    write_com(0x000B,0x0000);    DelayMs(10);
    write_com(0x000F,0x0000);    DelayMs(10);        //ЙЁГиїЄКјµШЦ·
    write_com(0x0041,0x0000);    DelayMs(10);
    write_com(0x0042,0x0000);    DelayMs(10);
    write_com(0x0048,0x0000);    DelayMs(10);
    write_com(0x0049,0x013F);    DelayMs(10);
    write_com(0x004A,0x0000);    DelayMs(10);
    write_com(0x004B,0x0000);    DelayMs(10);
    write_com(0x0044,0xEF00);    DelayMs(10);
    write_com(0x0045,0x0000);    DelayMs(10);
    write_com(0x0046,0x013F);    DelayMs(10);
    write_com(0x0030,0x0707);    DelayMs(10);
    write_com(0x0031,0x0204);    DelayMs(10);
    write_com(0x0032,0x0204);    DelayMs(10);
    write_com(0x0033,0x0502);    DelayMs(10);
    write_com(0x0034,0x0507);    DelayMs(10);
    write_com(0x0035,0x0204);    DelayMs(10);
    write_com(0x0036,0x0204);    DelayMs(10);
    write_com(0x0037,0x0502);    DelayMs(10);
    write_com(0x003A,0x0302);    DelayMs(10);
    write_com(0x003B,0x0302);    DelayMs(10);
    write_com(0x0023,0x0000);    DelayMs(10);
    write_com(0x0024,0x0000);    DelayMs(10);
    write_com(0x0025,0x8000);    DelayMs(10);
    write_com(0x004f,0);        //РРКЧЦ·0
    write_com(0x004e,0);        //БРКЧЦ·0
      DelayMs(20);
Uragan90 вне форума
Непрочитано 12.11.2010, 21:59
kison
И что - завелось?
kison вне форума
Непрочитано 13.11.2010, 17:10
Uragan90
Аватар для Uragan90
Сказал спасибо: 469
kison, Попытка №128 прошла не удачно! Может дисплей "раненый" попался, или надо точно узнать на каком контроллере да с нуля по даташиту писать процедуры инициализации и т.д. Спасибо всем кто пытался помочь!!!
Uragan90 вне форума
Непрочитано 14.11.2010, 02:17
Cybermaker
Сказали Спасибо 67 раз(а) в 61 сообщении(ях)
Cybermaker на пути к лучшему
Так он вообще завёлся или нет ?
Cybermaker вне форума
Непрочитано 14.11.2010, 13:10
Uragan90
Аватар для Uragan90
Сказал спасибо: 469
МК работает как заказывал, а дисплей даже и не признается!
Uragan90 вне форума
Непрочитано 14.11.2010, 19:22
Uragan90
Аватар для Uragan90
Сказал спасибо: 469
Чет не выходит ничего Может есть способ какой узнать навернека, живой дисплей или нет? Просто убедится!!! А то время потратиш, а он трупом все это время был МК уже настроил на работу от 72мгц, работает, на линиях дисплея изменяются уровни что видно осциллом, и хоть бы что
Uragan90 вне форума
Непрочитано 14.11.2010, 19:28
Cybermaker
Я занимался подобным дисплеем. Попробую откопать свой инит. Он на другом винте, который слегка посыпался. Так что на 100% гарантировать не могу.
P.S. Инит с vtrp мне тоже не подошел
Сказали "Спасибо" Cybermaker
Uragan90 (14.11.2010)
Непрочитано 15.11.2010, 11:48
Cybermaker
Нашел с трудом так как проет тестовый. Инит в функции lcd_show().
Тип файла: rar LPC1766 test.rar (320.2 Кб, 144 просмотров)
Uragan90 (15.11.2010)
Непрочитано 15.11.2010, 11:53
Cybermaker
Что именно происходит в ините сказать не могу. Кусок был передран из pdf'ки в которой были описаны иниты для контроллера под разные lcd. Первоисточник на моих компах искать уже бесполезно. Добавлю что в ините чуть сдвинуто начало видопамяти. Но индикатор при этом всё равно заводился.
Обнаружил строчку в комменте:
if (lcd_read_reg(0) != 0x9320) while (1); // stall if no LCD connected
Думаю её можно применить для теста работоспособности lcd как такового
Последний раз редактировалось Cybermaker; 15.11.2010 в 11:57.
Библиотека для работы с меню графического индикатора Tvenn Микроконтроллеры, АЦП, память и т.д 30 15.02.2011 17:41
Существует ли AT91SAM7Sxxx библиотека для Proteus? projects.org.ua Proteus 4 29.10.2010 02:09
Библиотека для создания меню, для графического индикатора Tvenn Микроконтроллеры, АЦП, память и т.д 2 03.09.2010 10:38
Библиотека последовательного доступа для AT45DB161, порт CodeVision LVII Микроконтроллеры, АЦП, память и т.д 4 19.06.2010 03:32
Часовой пояс GMT +4, время: 05:01.
