Измерение длительности импульса, TIM1
Непрочитано 05.07.2014, 18:01
eddy
Аватар для eddy
Сказал спасибо: 116
eddy на пути к лучшему
По умолчанию Измерение длительности импульса, TIM1
Я хочу измерить длительность импульса "эха" от датчика HC-SR04 (ультразвуковой дальнометр). Настроил TIM1 по даташиту:
	// capture/compare channel
	// channel CC1 (0-›1) stores low pulse length,
	// channel CC2 (1-›0) stores time period between two consequent zero-transitions
	TIM1_IER = TIM_IER_CC2IE;// | TIM_IER_UIE;// enable interrupt on CC2 & overflow
	// 1. Select the active input capture or trigger input for TIM1_CCR1 by writing the CC1S bits
	// 		to 01 in the TIM1_CCMR1 register (TI1FP1 selected).
	// IC1F = 0 - no filter
	// IC1PSC = 0 - no prescaler
	// TIM1_CCMR1: IC1F[3:0] | IC1PSC[1:0] | CC1S[1:0]
	TIM1_CCMR1 = 1;
	// 3. Select the active input for TIM1_CCR2 by writing the CC2S bits to 10 in the
	//		TIM1_CCMR2 register (TI1FP2 selected).
	TIM1_CCMR2 = 2;
	// 2. Select the active polarity for TI1FP1 (used for both capture and counter clear in
	// 		TIMx_CCR1) by writing the CC1P bit to 0 (TI1FP1 active on rising edge).
	// 4. Select the active polarity for TI1FP2 (used for capture in TIM1_CCR2) by writing the
	//		CC2P bit to 1 (TI1FP2 active on falling edge).
	// TIM1_CCER1: CC2NP | CC2NE | CC2P | CC2E | CC1NP | CC1NE | CC1P | CC1E
	TIM1_CCER1 = 0x20;
	// 5. Select the valid trigger input by writing the TS bits to 101 in the
	//		TIM1_SMCR register (TI1FP1 selected).
	// 6. Configure the clock/trigger controller in reset mode by writing the
	//		SMS bits to 100 in the TIM1_SMCR register
	// TIM1_SMCR: MSM | TS[2:0] | (reserved) | SMS[2:0]
	TIM1_SMCR = 0x54;
Вот так запускаю:
void US_start(){
	U8 i;
	TIM1_CNTRH = 0;
	TIM1_CNTRL = 0;
	US_flag = 0;
	// post initial pulse
	PORT(US_OUT_PORT, ODR) |= US_OUT_PIN;
	for(i = 0; i ‹ 160; i++) nop(); // wait at least for 10us
	PORT(US_OUT_PORT, ODR) &= ~US_OUT_PIN;
	// Enable the captures by writing the CC1E and CC2E bits to 1 in the TIM1_CCER1 register.
	TIM1_CCER1 |= 0x11;
Обрабатываю прерывание:
INTERRUPT_HANDLER(TIM1_CAP_COM_IRQHandler, 12){
	TIM1_CR1 = 0;TIM1_CCER1 &= ~0x11; // stop timer
	TIM1_SR1 = 0; // clear interrupt flags
	if(TIM1_SR2){ // overcapture: noice etc.
		TIM1_SR2 = 0;
		US_flag = 1;
	}else{
		US_flag = 2;
И определяю длительность (на время отладки вывожу все значения)
void US_check(){
	if(!US_flag) return;
	if(US_flag == 1){ // error - write message
		error_msg("can't measure pulse length");
	}else if(US_flag == 3){ // overflow
		error_msg("TIM1 overflow");
	}else{ // all OK - write measured length
		Pulse_length = TIM1_CCR2H ‹‹ 8 | TIM1_CCR2L;
		printUint((U8*)&Pulse_length,2);
		Pulse_length = TIM1_CCR1H ‹‹ 8 | TIM1_CCR1L;
		Pulse_length = TIM1_CNTRH ‹‹ 8 | TIM1_CNTRL;
	US_flag = 0;
(эта функция вызывается из бесконечного цикла в main(), если US_flag =! 0.
Проблема: все счетчики возвращают 0.
Не понимаю, как такое может быть, ведь сброс счетчика таймера происходит по CC1, а прерывание генерируется по CC2. Т.е. хоть что-то должно быть в регистре TIM1_CCR2!
Как такое может быть?
eddy вне форума
Непрочитано 05.07.2014, 19:23
eddy
Аватар для eddy
Сказал спасибо: 116
По умолчанию Re: Измерение длительности импульса, TIM1
Вообще странные вещи творятся. Воткнул в обработчик прерываний вот что:
Pulse_length = TIM1_CCR2L;
Pulse_length |= TIM1_CCR2H ‹‹ 8;
printUint((U8*)&TIM1_CCR2H,1);
printUint((U8*)&TIM1_CCR2L,1);
printUint((U8*)&TIM1_CCR1H,1);
printUint((U8*)&TIM1_CCR1L,1);
TIM1_SR2 = 0;
US_flag = 1;
}else{
US_flag = 2;
if(TIM1_SR1 & TIM_SR1_CC2IF){
uart_write("CCR2\n");
if(TIM1_SR1 & TIM_SR1_CC1IF){
uart_write("CCR1\n");
На Pulse_length всегда пишет 0
TIM1_CCR2 и TIM1_CCR1 постоянно имеют одни и те же значения: 0x02FD и 0x08FF, соответственно.
Вообще загадка.. Почему не меняется значение Pulse_length (он объявлен как extern volatile)? Почему не меняется содержимое регистров?
Если вход захвата оставить свободным, происходит зацикливание на прерывании по CC1 (с выводом указанных выше сообщений), а если тронуть пальцем - вывод прекращается, т.к. срабатывает прерывание по CC2.
Как это может быть так? Чушь же какая-то получается! Ну не может генерироваться прерывание по нарастающему фронту (CC1), если не было ни одного прерывания по спадающему (CC2)!
eddy вне форума
Непрочитано 05.07.2014, 20:42
niXto
Аватар для niXto
niXto на пути к лучшему
Попробуйте в дебагере
В ИАРе совершенно восхитительный отладчик-симулятор, позволит разобраться за считаные минуты
niXto вне форума
Непрочитано 05.07.2014, 20:46
eddy
Аватар для eddy
Сказал спасибо: 116
в дебагере
никогда gdb не использовал, не представляю, как в нем работать
Да и нафиг? можно ведь ассемблерный код посмотреть
В ИАРе
не смешно
eddy вне форума
Непрочитано 06.07.2014, 07:40
niXto
Аватар для niXto
Сообщение от eddy Посмотреть сообщение
Ну вот смотрите до звёздочек в глазах и пытайтесь догадаться, что вы делаете не так
Вместо того, чтобы мгновенно увидеть, работает ли таймер вообще, и по какой причине... Мы лёгких путей не ищем?
niXto вне форума
Непрочитано 06.07.2014, 11:27
Гы! Просто ИАР под Линухом не очень смотрится...
Сообщение от niXto
В ИАРе
не смешно
Непрочитано 06.07.2014, 11:30
eddy
Аватар для eddy
Сказал спасибо: 116
Может где примеры можно смотреть, как с этим захватом ШИМ на первом таймере работать?
А то вроде бы уже несколько раз код проверил - все по даташиту. Чего ему надо, не пойму.
eddy вне форума
Непрочитано 06.07.2014, 11:49
eddy
Аватар для eddy
Сказал спасибо: 116
Черт! Что-то я промухал (а в мануале как-то и не писалось об этом): похоже, надо сделать еще и TIM1_CR1 = 1! Видимо, разрешение захвата таки таймер не включает.
Но тогда непонятно, что за дурацкие прерывания у меня были с непонятными значениями счетчика.
// сижу в аэропорту, поэтому, к сожалению, проверить на железе не могу
eddy вне форума
Непрочитано 07.07.2014, 11:43
eddy
Аватар для eddy
Сказал спасибо: 116
Алилуйя! Так оно и есть. В мануале могли бы и написать, что таймер все равно врубать надо!
Итак, настраиваю таймер:
TIM1_PSCRH = 0;
TIM1_PSCRL = 15;
TIM1_IER = TIM_IER_CC2IE | TIM_IER_CC1IE | TIM_IER_UIE;
TIM1_CCMR1 = 1;
TIM1_CCMR2 = 2;
TIM1_CCER1 = 0x20;
TIM1_SMCR = 0x54;
Для начала измерения расстояния при помощи УЗ дальнометра запускается эта функция:
void US_start(){
	U8 i;
	TIM1_CNTRH = 0; TIM1_CNTRL = 0;
	TIM1_CCR2H = 0; TIM1_CCR2L = 0;
	US_flag = 0;
	TIM1_CCER1 |= 0x11;
	TIM1_CR1 = TIM_CR1_CEN; // turn on timer
Да, я лох - вместо запуска таймера в режиме одновибратора считаю импульсы. Конечно, в готовом варианте так делать ни в коем разе нельзя, но что уж тут... Пока что простительно - таки тесты же!
Я разрешил еще и прерывание по переполнению (на всякий случай) если расстояние будет больше 11м (все равно в этом случае будет ошибка и overcapture, но на всякий случай не помешает:
volatile U8 in_measure = 0; // flag of measurenent
// Timer1 Update/Overflow/Trigger/Break Interrupt
// in_measure == 1 means that we will get wrong result as pulse length is too long
// pulse of 65536us is 32768us to something == near 11 meters
INTERRUPT_HANDLER(TIM1_UPD_OVF_TRG_BRK_IRQHandler, 11){
	TIM1_SR1 &= ~TIM_SR1_UIF; // clear this flag
	if(!in_measure) return; // not process when there's nothing started
	US_flag = 3;
	TIM1_SR1 = 0;
	TIM1_SR2 = 0;
	in_measure = 0;
Ну и обработчик для измерения длительности импульса:
		TIM1_SR1 = 0; // clear all interrupt flags
		in_measure = 0; // work done
			TIM1_SR2 = 0;
			US_flag = 1;
		}else{
			US_flag = 2;
		TIM1_SR1 &= ~TIM_SR1_CC1IF; // clear this interrupt flags
		in_measure = 1; // start of measurement
Кстати, пробовал отключать обработку переполнения таймера в надежде выловить overcapture. Фигвам! Почему-то результаты все равно получались как будто бы все ОК.
А вот когда я отлавливаю переполнение, то при затыкании одной из пищалок пальцем получаю сообщение об ошибке.
В бесконечном цикле внутри main есть такая строчка
if(US_flag) US_check(); // end of measurement with ultrasonic?
которая запускает эту функцию:
void US_check(){
	unsigned long L;
		error_msg("measurement overcapture");
		Pulse_length =  ((U16)TIM1_CCR2H ‹‹ 8) | TIM1_CCR2L;
		// sound velocity == 340m/s in normal conditions
		// So distance = pulse * 1e-6(us) * 340 / 2
		// in millimeters this is equal of pulse*170/1000
		L = ((unsigned long) Pulse_length) * 170L;
		L /= 1000L;
		uart_write("Distance (mm): ");
		printUint((U8*)&L, 4);
	US_flag = 0;
Вполне приличный датчик (китайский HC-SR04): разброс значений где-то ±3мм на расстоянии в 2 метра. Правда, учитывая то, что скорость звука - величина очень уж непостоянная, без хотя бы термодатчика не обойтись, иначе показания совсем уж потолочными будут.
eddy вне форума
Непрочитано 08.07.2014, 11:26
eddy
Аватар для eddy
Сказал спасибо: 116
UPD. Забыл дать ссылку на код. Исправляюсь: на сосфорже, на гитхабе.
eddy вне форума
Измерение длительности импульса STM32 anton_1000 ARM 28 22.10.2013 10:51
Измерение длины импульса AGAT0365 Микроконтроллеры, АЦП, память и т.д 11 15.05.2013 21:09
STM32 измеренние длительности импульса anton_1000 Песочница (вопросы новичков) 22 26.08.2012 22:54
Ограничитель длительности импульса Pajatel Микроконтроллеры, АЦП, память и т.д 161 05.04.2012 00:35
Измерение длительности импульса fawkes Микроконтроллеры, АЦП, память и т.д 16 09.11.2008 16:41
Часовой пояс GMT +4, время: 20:13.
