Проблема при компиляции
Непрочитано 19.04.2013, 19:39
Urban 87
Аватар для Urban 87
Urban 87 на пути к лучшему
По умолчанию Проблема при компиляции
Выдает следующую ошибку
Building configuration: ei - Debug
Updating build tree...
main.c
stm32f10x_gpio.c
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 111
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 178
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 286
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 308
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 324
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 346
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 361
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 377
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 397
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 420
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 437
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 466
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 486
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 554
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 613
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_gpio.c 632
stm32f10x_rcc.c
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 273
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 338
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 357
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 383
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 404
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 431
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 568
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 612
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 638
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 664
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 703
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 731
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 770
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 832
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 865
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 882
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 896
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1067
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1098
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1129
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1188
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1219
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1240
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1253
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1285
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1332
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1406
Warning[Pe223]: function "assert_param" declared implicitly D:\ARM_Projects\EI2\STM\stm32f10x_rcc.c 1451
Linking
Error[Li005]: no definition for "assert_param" [referenced from D:\ARM_Projects\EI2\Debug\Obj\
stm32f10x_gpio.o]
Error while running Linker
Total number of errors: 1
Total number of warnings: 44
Как я понимаю проблема с ф-цией "assert_param" и её атрибутом"IS_RCC_HSE(RCC_HSE)". Но как я не пробовал рыть ничего не получается.
Вот картинки с архитектурой проекта, может я там что-то не правильно делаю.
Это папка с проектом:
Это проект в иаре:
А это подключение библиотек gpio и rcc .
Urban 87 вне форума
Непрочитано 19.04.2013, 20:26
Ara41
Сказал спасибо: 157
Ara41 на пути к лучшему
По умолчанию Re: Проблема при компиляции
Сообщение от Urban 87 Посмотреть сообщение
гугл
1 и 4 ссылки смотрели?
Ara41 вне форума
Непрочитано 21.04.2013, 15:11
dosikus
Аватар для dosikus
Сказал спасибо: 928
dosikus на пути к лучшему
Здесь два варианта :
Либо начать все таки читать справку по SPL .
Либо выкинуть ее на .
А так на лицо полное не осознание структуры проекта .
Осторожно , злой кот
dosikus вне форума
Сказали "Спасибо" dosikus
Urban 87 (21.04.2013)
Mega88 ошибка при компиляции out of range Andrewg Микроконтроллеры, АЦП, память и т.д 3 30.11.2010 21:27
Ошибка при компиляции Flowcode 3 проекта alexander70 Микроконтроллеры, АЦП, память и т.д 1 06.10.2009 17:56
Проблема при запуске Atmega16 zamsv Микроконтроллеры, АЦП, память и т.д 5 02.10.2009 12:52
Проблема компиляции в CodeVision art07 Микроконтроллеры, АЦП, память и т.д 2 14.08.2008 13:04
Проблема при запуске uc3855 Marlboro Источники питания и свет 0 19.07.2005 13:52
Часовой пояс GMT +4, время: 05:12.
