PIC24FJ64GA004 и CCS 4.065
Непрочитано 18.03.2009, 17:56
klg_08
klg_08 на пути к лучшему
По умолчанию PIC24FJ64GA004 и CCS 4.065
Выкладываю фрагмент проекта.
[/code#include "main.h"
#include ‹LCD.C›
#include ‹math.h›
void unsigned int16 HexBDC(unsigned int16 v)
hndr=0; tens_once=0;
while (v›99)
v=v-0x64; hndr++;
while (v›9)
v=v-0x0a; tens_once=tens_once+0x10;
tens_once=tens_once+v;
#int_TIMER1
void TIMER1_isr(void)
T1IF=0;
set_timer1(64779);
if (time_1s==2000)
Fl_1s=1;time_1s=0;
else
time_1s++;
if (Fl_measure)
SET_ADC_CHANNEL(0);
delay_us(2);
// ADCON0|=2;
while(DONE)
Ia.Nx=read_adc();
delay_us(2);
SET_ADC_CHANNEL(1);
delay_us(2);
// ADCON0|=2;
while(DONE)
Ib.Nx=read_adc();
delay_us(2);
SET_ADC_CHANNEL(2);
delay_us(2);
// ADCON0|=2;
while(DONE)
Ic.Nx=read_adc();
delay_us(2);
void main()
setup_adc_ports(sAN0|sAN1|sAN2|VSS_VDD);
setup_adc(ADC_CLOCK_DIV_64);
setup_spi(SPI_SS_DISABLED);
setup_timer1(TMR_INTERNAL|TMR_DIV_BY_;
setup_vref(FALSE);
enable_interrupts(INT_TIMER1 | INTR_LEVEL1);
T1IE=1;
SET_TRIS_B(1);SET_TRIS_A(3);SET_TRIS_C(0);
PR1=60536;
lcd_init();
Ua.No=Ub.No=Uc.No=10;
Ia.No=Ib.No=Ic.No=512;
lcd_gotoxy( 1, 1);
set_timer1(64779);
enable_interrupts(INTR_GLOBAL);
Flags=0;time_1s=0;
while (1)
while (!Fl_1s)
Fl_1s=0;
Fl_measure=1;
while (!Meas_done)
Fl_measure=0;
[/code#include ‹24FJ64GA004.h›
#device *=16
#device adc=10
#FUSES NOJTAG //JTAG disabled
#FUSES NOPROTECT //Code not protected from reading
#FUSES NOWRT //Program memory not write protected
#FUSES NODEBUG //No Debug mode for ICD
//#FUSES ICS3 //ICD communication channel 3
#FUSES IOL1WAY //Allows only one reconfiguration of peripheral pins
#FUSES WINDIS //Watch Dog Timer in non-Window mode
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES NOIESO //Internal External Switch Over mode enabled
#FUSES FRC_PLL //Internal Fast RC oscillator with PLL
#FUSES NOSKSFSM //Clock Switching Mode is disabled
#FUSES NOOSCIO //OSC2 is general purpose output
//#FUSES PR_PLL //PR //Pimary oscillaotr disabled
#FUSES I2C1SELD
#use delay(clock=20000000,RESTART_WDT)
struct Flui_map{
boolean beg;
boolean done;
}Fl_Ua,Fl_Ub,Fl_Uc,Fl_Ia,Fl_Ib,Fl_Ic;
struct UI
unsigned int32 Nx,X;
unsigned int8 cnt_smpl;
unsigned int8 cnt_beg;
unsigned int8 cnt_cicls;
unsigned int8 cnt_prm0;
unsigned int16 No;
}Ua,Ub,Uc,Ia,Ib,Ic;
unsigned int16 time_1s;
unsigned char Flags;
unsigned char hndr,tens_once;
#bit Meas_done=Flags.0
#bit Fl_measure=Flags.2
#bit Fl_1s=Flags.7
#byte AD1CHS=0x03228
#byte AD1CON1=0x0320
#byte AD1CON2=0x0322
#byte AD1CON3=0x0324
#byte AD1PCFG=0x032c
#byte AD1CSSL=0x0330
#byte ADC1BUF0=0x0300
#byte ADC1BUF1=0x0302
#byte ADC1BUF2=0x0304
#byte PR1=0x102
#byte IEC0=0x094
#byte IFS0=0x084
#bit T1IF=IFS0.3
#bit T1IE=IEC0.3
#bit samp=AD1CON1.1
#bit DONE=AD1CON1.0
#bit adon=AD1CON1.7
Среда MPLAB 8.20.
При отладке в симуляторе MPLAB программа работает. При использовании в MPLAB в качестве дебаггера Proteus VSM Viewer программа не входит в главный цикл, регистр OSCCON пустой, а в симуляторе правильно устанавливается (0х1120). В чем ошибка?
klg_08 вне форума
Непрочитано 18.03.2009, 18:23
MisterDi
Аватар для MisterDi
Сказал спасибо: 441
MisterDi на пути к лучшему
Есть подозрение что в Протеусе.
MisterDi вне форума
Непрочитано 19.03.2009, 14:42
rubel
Аватар для rubel
Сказал спасибо: 553
rubel на пути к лучшему
По умолчанию Re: PIC24FJ64GA004 и CCS 4.065
Сообщение от klg_08
Среда MPLAB 8.20.
Кажется вы не одиноки в данной теме.У меня тоже несрабатывает запись в OSCCON в проте. Смотри в проекте функцию pinmapconfig(переназначение пинов, компилятор C30). Протеус просит использовать байт -ориентированные инструкции записи в OSCCON (MOV.b по-ассемблерному). Компилятор не ругался по данному поводу и я забил на это дело, т.к. в железке все сработало и в моем Сишном варианте.
Возможно в этом проблема и у тебя. Покажи как ты пишешь в OSCCON и "unlocking sequence" как делаешь?
в датащите приведено примерно так:
asm volatile ( "MOV #OSCCON, w1
"MOV #0x46, w2
"MOV #0x57, w3
"MOV.b w2, ‹w1›
"MOV.b w3, ‹w1›
"BCLR OSCCON,#6");
Прикрепленный файл: 9366104.rar
rubel вне форума
Непрочитано 19.03.2009, 15:13
klg_08
Спасибо, rubel.
Я пишу на CCS и явно в регистр CSCON не пишу, т.к. использую директиву предпроцессора #use delay(clock=20000000,RESTART_WDT). При этом, как я говорил, в симуляторе MPLAB регистр CSCON устанавливается, если перхожу в Proteus (в ISIS или в MPLAB), регистр CSCON пустой. Может директива #use delay(clock=20000000,RESTART_WDT) для PIC24F не корректно работает
klg_08 вне форума
Непрочитано 19.03.2009, 15:37
rubel
Аватар для rubel
Сказал спасибо: 553
Сообщение от klg_08
Спасибо, rubel.
ну необязательно что для PIC24. вероятнее всего только для протеуса. Если в симуляторе MPLAB SIM все OK, то скорее всего и в шелезяке все будет ОK.
живой платки с МК у тебя нету я так понял?
rubel вне форума
Непрочитано 19.03.2009, 15:50
klg_08
[/quote]
живой платки с МК у тебя нету я так понял?[/quote]
Да втом то и дело, что только для PIC24. На CCS яписал программы для 12-й, 16-й и 18-й серий PIC'ов и все было нормально.
klg_08 вне форума
Непрочитано 19.03.2009, 16:49
rubel
Аватар для rubel
Сказал спасибо: 553
Сообщение от klg_08
Да ты не понял что я говорю. В 24х пиках совершенно другая архитектура, чем в 12й,16й и 18й сериях - это ты знаешь. для изменения некоторых битов в OSCCON 24го необходимо особым образом записать в него последовательно пару байт - так называемая "unlocking sequence" - типо разлочить регистр для изменения очень "критических" битов, которые могли бы(если бы не было этой фичи) при случайной ошибочной записи в них полностью нарушить выполнение программы и подвесить МК. Возможно используемая тобой директива компилятора "некорректно" (например, как в моей проге ) записывает эту самую "unlocking sequence". Но вопрос "некорректно для кого?(или чего?)". Ты видел какие-нить warningi от твоего компилятора по поводу OSCCON? - наверно нет. Загрузи в реальный МК твою прогу - и посмотри регистры дебаггером. если не будет работать - вот тогда можно говорить о некорректности работы директивы компилятора для семейства PIC. А пока что в активе - только очередной "матюк" от Proteusa - это не повод... (напиццо и забыццо )
Хотя с другой стороны - то, что прот требует выполнять эту инструкцию строго по даташиту - может оно и правильно. на выходных попробую сделать "правильно" - посмотрю заработает или нет в проте.
Или я не вьехал в тему и тебе важно именно чтобы работало в ПРОТЕУСЕ?
rubel вне форума
Непрочитано 19.03.2009, 20:39
klg_08
rubel, давай прервемся. У меня температура и раскалывается голова. Давай денька через два.
klg_08 вне форума
Непрочитано 20.03.2009, 11:16
DL36
Сказали Спасибо 17 раз(а) в 13 сообщении(ях)
DL36 на пути к лучшему
О переключении генераторов
Ошибку в модели протеуса нашел
316:                 SET_DIR(OUT6,Out);
  1450  A962D0     bclr.b 0x02d0,#3
317:                 SET_DIR(OUT7,Out);
  1452  A982D0     bclr.b 0x02d0,#4
Первая команда сбрасывает два бита 3 и 4 -й а вторая устанавливает 3-й.
Причем в МЛАБСИМ и железе все нормально.
Так, что с моделями надо осторожно уж очень сырые.
DL36 вне форума
Непрочитано 25.03.2009, 13:37
klg_08
Так у меня ничего не получилось с проектом(PIC24FJ64GA004) в Proteus(v7.2 sp6). При отладке в симуляторе MPLAB (V8.20) программа работает, прерывание от TMR1 происходят каждые 500мкс (такой период я задал). При выборе в качестве дебаггера Proteus, регистр OSCCON обнуляется и при попытке запуска программы, не выполняется самая первая команда программы goto 0x0003fe, очевидно из-за неработающего генератора PIC'а. Компилятор CCS v4.084.
Прикрепленный файл: 2168108.zip
klg_08 вне форума
CCS PIC C PCWHD 4.065 fmssp Микроконтроллеры, АЦП, память и т.д 38 09.06.2010 23:44
CCS PICC dosikus Микроконтроллеры, АЦП, память и т.д 30 16.10.2009 20:22
CCS C LIBRARIES ritvarsrizikovs Микроконтроллеры, АЦП, память и т.д 6 25.12.2008 13:39
CCS и ICD2 dosikus Микроконтроллеры, АЦП, память и т.д 0 02.12.2007 18:31
о CCS-PICC double_dash Proteus, KiCAD и другие ECAD 1 02.03.2007 23:19
Часовой пояс GMT +4, время: 09:30.
