Industrial:
PCA9601DP Dual bidirectional bus buffer
* SC16IS741IPW Single UART with I2C-bus/SPI interface
SC16IS752IPW Dual UART with I2C-bus/SPI interface
PCA9665PW Fm+ parallel bus to I2C-bus controller
PCA9675PW Remote 16-bit I/O expander for Fm+ I2C-bus
PCF8523TS Real-Time Clock (RTC) and calendar
PCF2129AT Integrated Real-Time Clock (RTC)
PCA9685PW 16-channel, 12-bit PWM Fm+ I2C-bus LED controller
* PCF85162T Universal LCD driver for low multiplex rates
PCF85176T Universal LCD driver for low multiplex rates
* PCA9635PW 16-bit Fm+ I2C-bus LED driver
* LM75BDP Digital temperature sensor and thermal watchdog
Computing:
* PCA9509DP Level translating I2C-bus / SMBus repeater (static)
* PCA9515ADP I2C-bus repeater (static)
* PCA9525 Fm I2C-bus bus buffer (no offset)
* PCA9539PW 16-bit I2C-bus low power I/O port
* PCA9548APW 8-channel I2C-bus switch
* SE97BTP DDR3 memory module temperature sensor and Serial Presence Detect (SPD)
Portable:
* NVT2002GF Bidirectional voltage-level translator
* PCA9574HR 8-bit I2C-bus level translating, low voltage GPIO
* PCA9535BS 16-bit I2C-bus and SMBus, low power I/O port
* PCA9575PW2 16-bit I2C-bus level translating, low voltage GPIO
* PCA9632DP1 4-bit Fm+ I2C-bus low power LED driver
* PCA9901DP One wire single LED driver for status indication
