Электронная библиотека Каталог книг и журналов по электронике
Ответ
Книги
Непрочитано 18.04.2009, 20:51   #31
SwanSwan
Аватар для SwanSwan
Сказал спасибо: 1,463
Сказали Спасибо 6,203 раз(а) в 1,470 сообщении(ях)
SwanSwan на пути к лучшему
Designing Embedded Hardware
http://letitbit.net/download/d7296ba...ition.chm.html
Описание: All of the topics could be easily found by a google search in much more details. The only good point after reading this book : a beginner knows how to pick from the smorgasbord of the Net.
Pretty useless for Engineers, even beginner Engineers already in the trade. And the book is not cheap !
SwanSwan вне форума   Ответить с цитированием
Непрочитано 18.04.2009, 21:45   #32
SwanSwan
Аватар для SwanSwan
Programming Embedded Systems_With C and GNU Development Tool
http://letitbit.net/download/e5567e5...ition.chm.html
Описание: Embedded system requires very diversified skillsets and I don't believe all of them can be covered in one book. In my opinion, the skilset of embedded system programming can be loosely grouped into two categories which are 8-bit and 32-bit. Engineers writing software for 8-bit microcontroller would usually be more involved in hardware details such as keypad debouncing, soft I2C etc. On the other hand, their 32-bit counterpart would spend more time designing more complex software that may includes bootloader, structured programming and RTOS. This book is more appropriate for those who intend to use 32-bit processor i.e. ARM rather than 8-bit microcontrollers i.e. 8051 and PIC.
I had quite some years of experience developing PIC/8051 firmware on Windwos platform, but did not had any experience on Unix. I found the book is particular useful in introducing building project on Unix platform, it is brief, but that's exactly what I wanted - short and simple.
Chapters on hardware, tool chain, memory, interrupts and RTOS are quite fundamental but could come handy to beginner in embedded world despite there are many other books that excel in these areas. However, I found Chapter 7 "Peripherals" is well written to teach you how to write a device driver. I believe this is something new to learn for engineers with either software or hardware background. Hardware engineers tend to access the hardware registers directly. On the other hand, softawre guys may not be familiar with low-level hardware. The authors talked about the device driver philosophy and elaborate on how to use struct and bitfield to provide hardware abstraction. Finally, a serial port device driver is presented as an example.
As a conclusion, this is a very good introductory book to 32-bit embedded programming, or better still if you use Unix/Linux/eCOS. For those who want to learn deeper about RTOS and hardware (say, how to write soft I2C, keypad/button debounce, LCD driver), you wouldn't gain much from this book.
‹center›
[img]nuke/users_images/18042009/8625856.jpg[/img]‹/center›
Непрочитано 18.04.2009, 21:50   #33
SwanSwan
Аватар для SwanSwan
Programming Embedded Systems in C and C ++
http://letitbit.net/download/15c66ab...and_C.chm.html
Сказали "Спасибо" SwanSwan
dima_iv71 (06.06.2010)
Непрочитано 18.04.2009, 23:58   #34
SwanSwan
Аватар для SwanSwan
PIC micro Microcontroller Pocket Reference
http://uploading.com/files/ODUP5PFN/...rence.pdf.html
Непрочитано 19.04.2009, 13:21   #35
SwanSwan
Аватар для SwanSwan
На Амазоне какие-то описания дебильные. Я уж лучше без них.
ARM System Developers Guide - Designing and Optimizing System Software
http://uploading.com/files/6000AI3H/ARM
Непрочитано 19.04.2009, 14:22   #36
SwanSwan
Аватар для SwanSwan
PIC Microcontrollers: An Introduction to Microelectronics
http://uploading.com/files/VLRB4KXB/PIC
Непрочитано 23.04.2009, 01:45   #37
gip
Аватар для gip
Сказал спасибо: 1,045
Сказали Спасибо 3,982 раз(а) в 926 сообщении(ях)
gip на пути к лучшему
Сообщение от SwanSwan
AVR animated tutorials
http://letitbit.net/download/993b46d...rials.zip.html
Описание Анимированный учебник по ассемблеру AVR для 2313, выполненный на Flash
А на бесплатный ресурс нельзя переложить? А то упорно СМС-ку требует, а бесплатный вариант почему-то не предлагает...
gip вне форума   Ответить с цитированием
Непрочитано 23.04.2009, 09:36   #38
delay
Сказал спасибо: 262
delay на пути к лучшему
У меня справа отображается ссылка free, нажал на нее, ввел код с картинки и скачал.
delay вне форума   Ответить с цитированием
Непрочитано 23.04.2009, 15:23   #39
SwanSwan
Аватар для SwanSwan
Пока проблемы, связанные со сменой компьютера. Через пару дней перезалью.
Кстати нашел я как победить Рапиду и Депозит (о своих проблемах с этими ресурсами я писал выше). Если кому интересно, могу рассказать.
Непрочитано 23.04.2009, 15:54   #40
ArtUrl1986
Аватар для ArtUrl1986
Сказал спасибо: 242
Сказали Спасибо 15 раз(а) в 13 сообщении(ях)
ArtUrl1986 на пути к лучшему
Сообщение от avr123-nm-ru
OFF - подскажите где можно по FTP заливать файлы кроме http://iFolder.ru ???
Хотите, на i-files.ru сделаю ФТП
ArtUrl1986 вне форума   Ответить с цитированием
Ответ
140, книги
Справочные ресурсы и ссылки родственной тематики xelos Делимся опытом 118 30.09.2025 19:48
Продолжение Про Книги Бесплатная Раздача Книг!!! ArtUrl1986 Электронная библиотека 4 25.03.2017 16:29
Книга по VHDL IZEVS Делимся опытом 2 10.05.2008 11:46
Часовой пояс GMT +4, время: 05:42.
