Мне нужно сделать Hidden pins видимыми (убрать то есть),нужно их самому соединить (на ATmega
А как сделать не знаю...
В ХЕЛПЕ ВОТ ЧТО:
Hidden Pins
Hidden pins are generally used to specify power supply connections to components in such a way that they do not clutter up the schematic. A hidden pin can be defined in one of two ways:
1.By clearing the Draw Body checkbox in the Edit Pin dialogue form. This must be done when making the device element. Such a pin will appear in the Pin Grid when the packaging tool is first invoked, and will be present in all packagings.
2.By clicking the Add Hidden Pin button. This creates a hidden pin that is specific to a given packaging, and is implicitly common to all its elements.
кнопки Add Hidden Pin нет, есть только Add pin
а первый пункт как-то непонимаю (глупый)
