Может я что-то не понимаю подскажите, но у меня при симуляции
PIC16F876A через случайный промежуток времени вываливается ЭТО:
SIMULATION LOG
Design: C:\mplab\binclock\cl_876.DSN
Doc. no.: ‹NONE›
Revision: ‹NONE›
Author: ‹NONE›
Created: 08/08/05
Modified: 15/08/05
Compiling source files...
Processing cl1.asm...
up to date.
Build completed OK.
Compiling netlist...
Linking netlist...
Partition analysis...
Simulating partition 1 [36F3F6CA]...
Animation started sucessfully...
PROSPICE Release 6.7 SP0 (C) Labcenter Electronics 1993-2005.
SPICE Kernel Version 3f5. (C) Berkeley University ERL.
Reading netlist...
Reading SPICE models...
Loading library 'ANALOGD.SML'
Loading library 'APEX.SML'
Loading library 'BURRBROWN.SML'
Loading library 'ELANTEC.SML'
Loading library 'FAIRCHLD.SML'
Loading library 'INTERSIL.SML'
Loading library 'LINTEC.SML'
Loading library 'NATOA.SML'
Loading library 'SUPERTEX.SML'
Loading library 'TECCOR.SML'
Loading library 'TEX101.SML'
Loading library 'TEX301.SML'
Loading library 'TEX3_1.SML'
Loading library 'TEX401.SML'
Loading library 'TEX5_1.SML'
Loading library 'VALVES.SML'
Loading library 'ZETEX.SML'
Building circuit...
Instantiating SPICE models...
[U1] PIC16 model release 6.7 SP0 simulating PIC16876 device.
[U1] Loaded 256 bytes of persistent EEPROM data.
[U1] Loading HEX file 'cl1.HEX'.
[U1] Read total of 672 bytes from file 'cl1.HEX'.
[U1] Loaded 336 program words and 0 data bytes.
[SPICE] Error 106 - TRAN: Timestep too small; time = 0.239989, timestep = 3.46945e-018: trouble with node "#00012"
Real Time Simulation FAILED.
Может сразу вывалиться, может чуть чуть поработать, а топом вывалиться. Как с ЭТИМ бороться?
Проект - часы на ПИК с динамической индикацией светодиодами.
