| Электронная библиотека Каталог книг и журналов по электронике |
Книги
24.08.2010, 18:17
Сказал спасибо: 337
Сказали Спасибо 30,223 раз(а) в 6,809 сообщении(ях)
Re: Книги
Practical Balancing of Rotating Machinery
Название: Practical Balancing of Rotating Machinery
Автор: Derek Norfield
Издательство: Elsevier Science
Год: 2006
Страниц: 218
ISBN: 1856174654
Формат: PDF
Язык: английский
Rotating machinery (eg pumps, motors, compressors) is normally manufactured to precise measurements but there comes a point when the costs of manufacture mean that further precision is not cost-effective and thus any slight imbalance inherent in the machine will need to be attended to after manufacture. When such machinery is in operation, often at very high speeds of thousands of revs per minute, any imbalance will set up vibration and often noise. In addition, such imbalance will cause extra wear and loss of efficiency in the machine. The answer is to balance the affected parts of the machine so that it operates smoothly and efficiently.
This book is a practical account of such balancing techniques e.g how to balance a rotor, how to set up and verify performance of a balancing machine, and procedures for on-site balancing. In addition, other common causes of vibration will be covered e.g. misalignment, bad bearings and looseness.
http://shareflare.net/download/17364...inery.rar.html
http://turbobit.net/hli5aflcirug.html
http://www.filesonic.com/file/175993..._machinery.rar
Эти 2 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
24.08.2010, 20:26
Сказал спасибо: 4,738
Сказали Спасибо 4,822 раз(а) в 582 сообщении(ях)
Re: Книги
Discrete Semiconductor Circuit Examples
Примеры схем на дискретных полупроводниковых элементах
Manual Int. Telephone Corporation, 1973, 182 pages
PDF - 3 mb
http://uploading.com/files/8bfeme16/...tExamples.rar/
http://www.filesonic.com/file/175274...itExamples.rar
I. Voltage and Current Stabilizers
II. Amplifiers
III. Oscillators
IV. Digital and Pulse Circuits
V. Timer and Relay Circuits
VI. Control Circuits
VII. Metering and Monitor Circuits
Эти 4 пользователя(ей) сказали Спасибо kipiaxxx за это сообщение:
24.08.2010, 20:31
Сказали Спасибо 772 раз(а) в 101 сообщении(ях)
Re: Книги
Современные мониторы
Автор: Н.А. Тюнин, А.В. Родин
Издательство: СОЛОН-ПРЕСС
Серия и выпуск: Ремонт, №101
Год: 2007
Страниц: 148, ил.
Язык: Русский
Формат: djvu / rar
Размер(+5% восс.): 8,0 Mb
В данной книге рассмотрены популярные модели современных ЭЛТ и ЖК мониторов известных производителей: Daewoo, LG Electronics, Philips, Rolsen, Rover, Samsung Electronics и ViewSonic. По каждой модели приводятся принципиальная схема, подробное описание работы всех ее составных частей и, конечно, типовые неисправности и методика их поиска и устранения. Кроме того, по нескольким моделям приведена методика регулировки узлов, которая необходима после их ремонта.
Книга предназначена для специалистов, занимающихся ремонтом оргтехники, а также для радиолюбителей и обычных пользователей, интересующихся этой темой.
Скачать книгу "Современные мониторы"
TurboBit.net
Cash-File.com
Эти 9 пользователя(ей) сказали Спасибо yunik77 за это сообщение:
24.08.2010, 21:05
Re: Книги
Бестрансформаторные усилители мощности. Справочник
Варакин Л.Е., М.: Радио и связь, 1984. 128с.
djvu - 1.7 мб - http://www.onlinedisk.ru/file/501473/
Приведены материалы для расчета высококачественных бестрансформаторных усилителей мощности и их типовые схемы. Даны методика расчета и схемы реальных базовых усилителей. Обобщены справочные данные по биполярным и полевым мощным транзисторам, транзисторам средней мощности и т. д.
Эти 6 пользователя(ей) сказали Спасибо kipiaxxx за это сообщение:
24.08.2010, 21:40
Сказал спасибо: 337
Re: Книги
Electronic Science Experiments
Название: Electronic Science Experiments
Автор: A. K. Roy
Издательство: Business Promotion Publishing
Год: 1983
Страниц: 73
Формат: PDF
Язык: английский
I found that this book explained the necessary and important concepts well. It s a good book as an introduction to Semiconductors, especially if you need to understand the concepts before you go into the deeper stuff. It also provides the mathematics on deriving some of the equations without expecting the reader to already to know how the equations came about. Good for undergraduates & graduates who are starting to take stuff in this field.
http://shareflare.net/download/50828...K_Roy.rar.html
http://turbobit.net/y3448ve95gp5.html
http://www.unibytes.com/_35tX6CzG-gB
http://depositfiles.com/files/e8pqwpcuf
http://letitbit.net/download/26548.2...K_Roy.rar.html
Последний раз редактировалось mihail62; 26.08.2010 в 23:39.
Эти 9 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
25.08.2010, 00:02
Сказал спасибо: 337
Re: Книги
555 Timer & Its Applications
Название: 555 Timer & It's Applications
Автор: M.C.Sharma
Издательство: Promotion Publishing
Год: 1977
Страниц: 48
Формат: PDF
Язык: английский
The 555 Timer IC is an integrated circuit (chip) implementing a variety of timer and multivibrator applications. The IC was designed by Hans R. Camenzind in 1970 and brought to market in 1971 by Signetics (later acquired by Philips). The original name was the SE555 (metal can)/ NE555 (plastic DIP) and the part was described as "The IC Time Machine"
http://turbobit.net/tgh650cdcjq9.html
http://shareflare.net/download/35253...tions.rar.html
http://www.unibytes.com/iNt8eA0v1.wB
Эти 6 пользователя(ей) сказали Спасибо mihail62 за это сообщение:
25.08.2010, 01:19
Сказал спасибо: 1,045
Сказали Спасибо 3,982 раз(а) в 926 сообщении(ях)
Re: Книги
Сообщение от Halex07
Если кому не нравится, уберу и эти.
Зачем, это же книги?!
25.08.2010, 03:39
Как распаковать поврежденный архив
Формат файла: doc (Word)
Разработчик: группа
Платформа: Windows All
Язык: Русский
Размер файла: 5.34 Mb
О книге:
Был ли у вас случай когда при распаковке архива выдается ошибка и файл из архива получить не удается? Что же делать удалять архив и качать заново, а если архив опять не удастся распаковать. Не спешите ничего удалять, благодаря данному пособию вы узнаете как быстро и качественно востановить поврежденный архив.
http://letitbit.net/download/7467.a1...vkaAr.rar.html
http://depositfiles.com/files/kxfblubdd
P.S.
После скачивания обнаружил, что основной вес занимает "довесок" (и не один).
Переложил единственный файл, имеющий отношение к теме (около 143К):
http://depositfiles.com/files/w7ukowek8
Последний раз редактировалось gip; 25.08.2010 в 04:54.
Эти 15 пользователя(ей) сказали Спасибо gip за это сообщение:
achertkov (28.08.2010), Air777 (27.10.2010), fesha1 (04.09.2010), kadet11 (25.08.2010), kipiaxxx (25.08.2010), kovtun48 (27.08.2010), Kroom73 (02.09.2010), maligor (25.08.2010), mvkarp (09.09.2010), Sanyo (28.08.2010), Stjopa (13.12.2010), Uz_Sleep_Walker (25.08.2010), VictorB (30.08.2010), Wlad_alex (25.08.2010) |
25.08.2010, 07:49
Сказал спасибо: 14
Сказали Спасибо 1,086 раз(а) в 221 сообщении(ях)
Re: Книги
Hacking GPS
Автор: Kathie Kingsley-Hughes
Серия: Extreme Tech
Издательство: Wiley Publishing, Inc.
Год: 2005
Страниц: 334
Язык: Engl.
Формат: pdf
Качество: отличное
GPS-навигатор - замечательный прибор, но знаете ли вы, что в инструкции по эксплуатации описаны от силы десять процентов его возможностей? Эта книга раскроет множество секретов, которые позволят вам использовать ваш GPS на все сто! Как получить доступ к секретным кодам? Как подобрать оптимальный источник питания? Как подключить GPS к другим устройствам? Как обновить встроенное программное обеспечение? Что представляют собой данные, принимаемые GPS, и как с ними работать? Ответы на эти и множество других вопросов вы найдете в предлагаемой книге.
Скачать с:
Турбобит
Депозит
Летитбит
Shareflare
Эти 8 пользователя(ей) сказали Спасибо raaraa за это сообщение:
Часовой пояс GMT +4, время: 00:19.
