STM32F303K6 - виснет при приёме сообщений CAN
14.12.2016, 13:06
Приветствую всех,
прошу помощи; не получается принимать сообщения, как только микроконтроллер принимает сообщение он тут же подвисает
#include "stm32f30x.h"
void TIM2_IRQHandler(void){
CanTxMsg canMessage;
TIM_ClearITPendingBit(TIM2, TIM_IT_Update);
if(GPIO_ReadOutputDataBit(GPIOA, GPIO_Pin_1)){
GPIO_WriteBit(GPIOA, GPIO_Pin_1, Bit_RESET);
}else{
GPIO_WriteBit(GPIOA, GPIO_Pin_1, Bit_SET);
canMessage.StdId = 0x123;
canMessage.ExtId = 0;
canMessage.RTR = CAN_RTR_DATA;
canMessage.IDE = CAN_ID_STD;
canMessage.DLC = 8;
canMessage.Data[0] = 0;
canMessage.Data[1] = 1;
canMessage.Data[2] = 2;
canMessage.Data[3] = 3;
canMessage.Data[4] = 4;
canMessage.Data[5] = 5;
canMessage.Data[6] = 6;
canMessage.Data[7] = 7;
CAN_Transmit(CAN1, &canMessage);
void USB_LP_CAN1_RX0_IRQHandler(void) {
int main() {
GPIO_InitTypeDef GPIO_InitStructure;
CAN_InitTypeDef CAN_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
CAN_FilterInitTypeDef CAN_FilterInitStructure;
TIM_TimeBaseInitTypeDef TIM_TimeBase_InitStructure;
TIM_OCInitTypeDef TIM_OC_InitStructure;
//CanTxMsg canMessage;
SystemInit();
SystemCoreClockUpdate();
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //PA1
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure); //LED1
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //PA2
GPIO_Init(GPIOA, &GPIO_InitStructure); //LED2
/* CAN GPIOs configuration **************************************************/
/* Connect CAN pins to AF9 */
GPIO_PinAFConfig(GPIOA, GPIO_PinSource11, GPIO_AF_9);
GPIO_PinAFConfig(GPIOA, GPIO_PinSource12, GPIO_AF_9);
/* Configure CAN RX and TX pins */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
/* NVIC configuration ************************************************** *****/
NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriori ty = 0x0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX1_IRQn;
/* CAN configuration ************************************************** ******/
/* Enable CAN clock */
/* CAN register init */
CAN_DeInit(CAN1);
CAN_StructInit(&CAN_InitStructure);
/* CAN cell init */
CAN_InitStructure.CAN_TTCM = DISABLE;
CAN_InitStructure.CAN_ABOM = DISABLE;
CAN_InitStructure.CAN_AWUM = DISABLE;
CAN_InitStructure.CAN_NART = ENABLE;
CAN_InitStructure.CAN_RFLM = DISABLE;
CAN_InitStructure.CAN_TXFP = DISABLE;
CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;//CAN_Mode_LoopBack//CAN_Mode_Normal
CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
/* CAN Baudrate = 500KBps (CAN clocked at 36 MHz) */
CAN_InitStructure.CAN_BS1 = CAN_BS1_9tq;
CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq;
CAN_InitStructure.CAN_Prescaler = 2;
CAN_Init(CAN1, &CAN_InitStructure);
/* CAN filter init */
CAN_FilterInitStructure.CAN_FilterNumber = 0;
CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
//CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0401 ‹‹ 5;
//CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
//CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0xFFFF;
//CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0xFFFF;
CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
CAN_FilterInit(&CAN_FilterInitStructure);
/* Enable FIFO 0 message pending Interrupt */
CAN_ITConfig(CAN1, CAN_IT_FMP0, ENABLE);
//TIMER BLINK LED
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
TIM_TimeBase_InitStructure.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBase_InitStructure.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBase_InitStructure.TIM_Period = 500; //1999
TIM_TimeBase_InitStructure.TIM_Prescaler = 17999;
TIM_TimeBaseInit(TIM2, &TIM_TimeBase_InitStructure);
TIM_ITConfig(TIM2, TIM_IT_Update, ENABLE);
NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriori ty = 0x0F;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
TIM_Cmd(TIM2, ENABLE);
while(1) {
то есть светодиод мыргает ~2 раза в секунду и отправляет сообщения, это работает, отправленные сообщения вижу CAN анализатором, но как только я CAN анализатором отправляю любое сообщение проц подвисает и светодиод на PA1 мыргать перестаёт (похоже подвисает не core, а переферия потому что в ST-LINK core можно останавливать, запускать, ресететить, ничего не меняется пока не сделаешь system reset)
передачу сообщений в TIM2_IRQHandler отключал, ничего не меняется в поведении, всё также подвисает
если mode переключить в loopback то подвисает тут после ресета, очевидно при приёме своего же первого сообщения
подопытный: STM32F303K6
CAN driver: SN65HVD232D
внешний кварц 4 мгц, внутренний такт 72 мгц
IDE: Keil uVision 5
14.12.2016, 18:15
Сказал спасибо: 5,035
Re: STM32F303K6 - виснет при приёме сообщений CAN
Сообщение от lau-de
А какой анализатор? Как называется? Какой приемопередатчик в анализаторе, и какой на плате?
15.12.2016, 02:05
UPA-USB CAN analyser от elrasoft
наверно 82с250, затёрто на нём
на плате вроде написал что:
15.12.2016, 22:28
C такими драйверами не работал. Обычно использую TJA1040 и TJA1941. Начинал с микрочиповских, но у них цена кусачая.
В общем, я бы советовал взять логический анализатор, поцепиться на логические входы и выходы драйверов CAN, и посмотреть, что там происходит во время обмена.
Полезная информация для периода отладки может быть получена при помощи светодиодов. Я цепляю по светодиоду на логический вход и выход драйвера, чтобы они светились от логического нуля. И тогда хорошо видно, когда проходит одиночный пакет, или группа пакетов, или сплошной поток пакетов.
17.12.2016, 06:21
надо было просто вместо общего startup_stm32f30x.s использовать startup_stm32f334x8.s
всё заработало, всем всё равно спасибо
Часовой пояс GMT +4, время: 19:07.
